In the property of Storm Drainage Structure, in the Part Data chapter some lines are not highlighted (part Type, Part Subtype etc) and some are - Material, Frame, Grate etc. For last ones in the Value column I can type whatever I want to (Reinforced Concrete, Standard).
Question is - how can I add several more "highlighted" lines? Or change name of existing ones - say, rename Frame into Standard Detail Number?
Thank you,
