Valued Contributor
rafaelaustin
Message 1 of 8 (298 Views)
Channel assembly with rock wall fixed to ROW align/profile
298 Views, 7 Replies
12-10-2012 08:06 AM
I'm trying to create assemblies for the attached PDF, but I just can't figure out how to gereate the walls "starting" from the ROW align/prof while having the channel bottom follow the main align/profile.
Based on our design, the sides need to "start" at the ROW, go out 5' for a fixed distance, then down at 1:8 (vert) till it projects down to the bottom of the channel. I can build these seperately, but how do I get them to work together?
Also, I'm stumped at how to do the "variable" segments in #2 that connect the channel bottom to the sides that project down from the ROW. I've looked for tutorials on using a MarkPoint, but I haven't found anything that helps.
Thanks in advance!
Valued Contributor
rafaelaustin
Message 2 of 8 (297 Views)
Re: Channel assembly with rock wall fixed to ROW align/profile
12-10-2012 08:07 AM in reply to: rafaelaustin
To clairify, I'm not trying to create the zig-zag wall accurately, we're just going to show it as a 1:8 (vert) face.
Valued Contributor
rafaelaustin
Message 3 of 8 (294 Views)
12-10-2012 08:10 AM in reply to: rafaelaustin
Also, I already have an alignment and profile for both existing RT/LT ROW that I am trying to follow.
I've always had cases that are like the RT side of #3, where I just project out to an existing ROW align/prof and attach to that. But I've never done one that projects both from the flowline outward and the ROW inward at the same time.
Valued Contributor
rafaelaustin
Message 4 of 8 (268 Views)
12-10-2012 11:34 AM in reply to: rafaelaustin
I’m thinking I just need to suck it up and do it all with features lines and grading objects. That’s not going to look pretty.
1)      Create CHAN-1-BOTT surface with feature lines, stepped offset and grading object projecting to ROW. Create feature lines at ROW, stepped offset to top of wall then project down to bottom surface to create CHAN-1-RT and CHAN-1-LT. Merge into CHAN-1-FG surface.
2)      Create CHAN-2-BOTT with stepped offset, only for concrete channel. Create 2% slope down from ROW, leaving gap between surfaces. Paste both into CHAN-2-FG and let gap be filled by surface.
3)      Similar.
Maybe I can create the channel bottom surfaces with a corridor to save a little time and offer some flexibility if the design changes.
Opinions?
Valued Mentor
fcernst
Message 5 of 8 (265 Views)
12-10-2012 11:45 AM in reply to: rafaelaustin
Do not start sucking.
This is easily done with a MarkPoint, LinkToMarkedPoint and Offset Assemblies. I quickly worked it up show one side for example below:
Fred Ernst, PE
C3D 2015
Ernst Engineering
www.ernstengineering.com
Valued Contributor
rafaelaustin
Message 6 of 8 (237 Views)
12-11-2012 08:16 AM in reply to: fcernst
Thanks. A coworker from another office worked up a solution, that I admit I haven't completely figured out. I post a step-by-step here later after I have it broken down. Thanks for your input!
Valued Mentor
fcernst
Message 7 of 8 (231 Views)
12-11-2012 09:30 AM in reply to: rafaelaustin
Great. Glad to hear it gave you the idea how this could work with one Corridor object.
It will keep everything nicely organized and coordinated for you.
Fred Ernst, PE
C3D 2015
Ernst Engineering
sboon
Message 8 of 8 (225 Views)
12-11-2012 11:45 AM in reply to: fcernst
LinkSlopeBetweenPoints may be a good solution for this, if you're still having trouble.  If you set the ditch width to zero, then you can essentially create an intersection at the bottom of your wall given the two known starting points and the two known slopes.
