Civil 3D Forum
Changing the default of “design speed” appearing in the create alignment,
2 REPLIES 2
JamaL9722060
370 Views, 2 Replies
I’m wondering how the design speed appearing in the “create alignment” dialogue box can be changed such that the second time the “create alignment” dialogue box is launched then the new value for the speed is displayed (attached)
Thank you
Best
Jamal
Jamal Numan
2 REPLIES 2
if you go to the prospector, to the settings tab, right click on item "Alignment" ==> "Edit settings" ==> this opens a dialog with default settings when creating an alignment, you find there a section "settings for criteria based design" and within this section you find the default speed.
And to make sure: that value can be overridden at this position: in the settings tab ==> "Alignment" ==> "Commands" ==> there you find settings named like "CreateAlignment....." ==> and everyone of those items can have a overrides depending on how the alignment is created.
(hopefully my translations are helpfull for you, I have only access to the German Civil3D)
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Many thanks alfred for the help. It works
Thank you
Best
Jamal
Jamal Numan
Rail Community
