Civil 3D Forum
Changing reference surface in a pipe network
7 REPLIES 7
Message 1 of 8
pcloutier82
7705 Views, 7 Replies
I have an existing pipe network, and I need to reference it to a another surface.  Is there a quick way of doing it instead of click on each part individually and changing the surface?
Thank You
7 REPLIES 7
Message 2 of 8
Joe-Bouza
in reply to: pcloutier82
select the network in the prospector. below in the panaram scroll to the right you will see a "reference surface" col. highlight the structures, right click the col heading choose edith and pick your surface
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People)
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win10 OS
Message 3 of 8
pcloutier82
in reply to: Joe-Bouza
It worked! Thank you.
Now I need to change to surface in the profile view, any methods to do that?
Message 4 of 8
Joe-Bouza
do another surface profile, grip the profile view>> profile view properties>> profile tab>> clear the check box of the one you dont want.
there is another way that could have saved you a lot of trouble: in the original surface>> surface properties>> deinition tab>> highlight all the definitions>> right click remove, choose mark out of date. Now paste the new surface into the old >> rebuild.
this way you wouldn't have had to do anything else. Sorry I didn't read between the lines.
Lesson: in civil3d modify objects instead of deleting and making new, when you can
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Message 5 of 8
pcloutier82
All good, thanks for the help!
Message 6 of 8
jdavisQLW2M
thanks!
Message 7 of 8
mgrocki
This solution is quite cumbersome for a pipe network with alot of structures. is there any way to change all structures at once? seems like the solution only allows you to change one structure at a time.
Message 8 of 8
Joe-Bouza
in reply to: mgrocki
Just select all the structures in the Panorama(Shift scroll to bottom pick)  first then right click the heading.
Same for reference alignment if desired
Also see my post 4 of 8 for the future
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win10 OS
Rail Community
