Civil 3D Forum
Changing reference surface in a pipe network
7 REPLIES 7
Message 1 of 8
pcloutier82
7764 Views, 7 Replies
I have an existing pipe network, and I need to reference it to a another surface.  Is there a quick way of doing it instead of click on each part individually and changing the surface?
Thank You
7 REPLIES 7
Message 2 of 8
Joe-Bouza
in reply to: pcloutier82
select the network in the prospector. below in the panaram scroll to the right you will see a "reference surface" col. highlight the structures, right click the col heading choose edith and pick your surface
Joe Bouza
Message 3 of 8
pcloutier82
in reply to: Joe-Bouza
It worked! Thank you.
Now I need to change to surface in the profile view, any methods to do that?
Message 4 of 8
Joe-Bouza
do another surface profile, grip the profile view>> profile view properties>> profile tab>> clear the check box of the one you dont want.
there is another way that could have saved you a lot of trouble: in the original surface>> surface properties>> deinition tab>> highlight all the definitions>> right click remove, choose mark out of date. Now paste the new surface into the old >> rebuild.
this way you wouldn't have had to do anything else. Sorry I didn't read between the lines.
Lesson: in civil3d modify objects instead of deleting and making new, when you can
Joe Bouza
Message 5 of 8
pcloutier82
All good, thanks for the help!
Message 6 of 8
jdavisQLW2M
thanks!
Message 7 of 8
mgrocki
This solution is quite cumbersome for a pipe network with alot of structures. is there any way to change all structures at once? seems like the solution only allows you to change one structure at a time.
Message 8 of 8
Joe-Bouza
in reply to: mgrocki
Just select all the structures in the Panorama(Shift scroll to bottom pick)  first then right click the heading.
Same for reference alignment if desired
Also see my post 4 of 8 for the future
Joe Bouza
Rail Community
