Civil 3D Forum
Changing Pressure Pipe Catalog location-2014
4 REPLIES 4
CADmgrMike
1961 Views, 4 Replies
I copied the pressure pipe catalogs to our local network and in C3D 2014 set the catalog to the network location.
When I close C3D and reopen, it reverts back to the original catalog location on my C drive.
Setting a different location for regular pipe networks works fine.
Is there something I'm missing or does this method not work for pressure networks.
Thanks.
Mike Porter
https://provostandpritchard.com/
4 REPLIES 4
BrianHailey
in reply to: CADmgrMike
I believe that setting is saved per drawing. Set it in the drawing, save the drawing, close, and reopen. Does that work?
Brian J. Hailey, P.E.
GEI Consultants
My Civil 3D Blog
CADmgrMike
in reply to: BrianHailey
It appears you are correct, but it isn't that way with the Pipe Nework Catalog location.
That's very confusing.Smiley Sad
Mike Porter
CADmgrMike
Back to square 1.
Not sure when it happens, but trying to tweak the catalog, it reverts back to the install location.
Mike Porter
There is a location in your Registry that shows the location of any Catalogs attached.
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.1\ACAD-E000:409\Profiles\<<C3D_Imperial>>\Preferences\AeccPressurePipes100
If you load a custom profile, look in that folder.
Rail Community
