Distinguished Contributor
csevers
Message 1 of 4 (584 Views)
Changing pipe sizes
584 Views, 3 Replies
08-23-2012 02:58 PM
I'm fairly new to using the pipe network features and knew this issue was approaching.
I know how to edit the pipe part properties to change a pipe from the size indicated in my parts list to another common size for the particular material specified. However, I've run into a non-standard size that is not in the dropdown menu, how can I add another size to the list?
Basically, I need a 1.5" on the list in the attached screep cap.
Chris Severs, EI
Windows 7 x 64 bit
NVidia Quadro 2000 Dual Monitor
6.00 GB RAM
Intel Xeon W3550 @ 3.07 GHz
Civil 3D 2013 SP 2, Civil 3D 2012 SP2, Civil 3D 2011 V3, Civil 3D 2010 V3
You need to go into part builder and add the size. Try THIS
Joe-Bouza
Message 2 of 4 (569 Views)
Re: Changing pipe sizes
08-23-2012 08:23 PM in reply to: csevers
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
csevers
Message 3 of 4 (548 Views)
08-24-2012 06:00 AM in reply to: csevers
Thanks!
Chris Severs, EI
Windows 7 x 64 bit
6.00 GB RAM
Joe-Bouza
Message 4 of 4 (529 Views)
08-24-2012 01:39 PM in reply to: csevers
HTH
Thank you
HP Z210 Workstation
12 GB Ram
64 Bit Win7 OS
