Civil 3D Forum
Changing pipe sizes
3 REPLIES 3
csevers
1342 Views, 3 Replies
Changing pipe sizes
I'm fairly new to using the pipe network features and knew this issue was approaching.
I know how to edit the pipe part properties to change a pipe from the size indicated in my parts list to another common size for the particular material specified. However, I've run into a non-standard size that is not in the dropdown menu, how can I add another size to the list?
Basically, I need a 1.5" on the list in the attached screep cap.
Chris Severs, PE
Windows 7 Enterprise SP1 64 bit
64.0 GB RAM
Intel Xeon E5-2650 v3 @ 2.30GHz
NVIDA Quadro M4000
Civil 3D 2014
3 REPLIES 3
Joe-Bouza
in reply to: csevers
You need to go into part builder and add the size. Try THIS
Your Name
csevers
Thanks!
Chris Severs, PE
64.0 GB RAM
NVIDA Quadro M4000
Civil 3D 2014
Joe-Bouza
HTH
Your Name
Rail Community
