Solved by Civil3DReminders_com. Go to Solution.
Delete the SI from the Parts List for the concrete pipe. Use the upper case instead of the preserve case.
If the pipe has already been placed change the description of the pipes.
The “concrete Pipe” an be capitalized by highlighting the "Description" portion in your "what is making the pipe text.png" > select preserve case > Change capitalization to uppercase. Then click the arrow to push it over to the viewer.
"Material" values can also be added to Parts Lists & then used in leu of description in pipe labels such as 12" RCP etc.
These values get stored in the AeccSharedPropertyLists.xml file.
For new pipes change it in the image, for old pipes change the description in Pipe Properties.
