Civil 3D Forum
Welcome to Autodeskā€™s Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
changing number of decimals
1 REPLY 1
229 Views, 1 Reply
hey there i have an issue i cant resolve i am working on this project and i want to remove the decimal digits as shown in this picture "L=50.000" i want it to be L=50.0 also S=0.000 i need it to be S=0.00
how to shorten these numbers ?
by the way this is a pipe label
thanks for your help
1 REPLY 1
sboon
Select a label and right click to edit the style.  Switch to the Layout tab, select the component you need to change and use the ellipsis button on the right side of the Contents line to edit it.  If you select the portion of the text to edit, as I have then the current properties for it will appear on the left.  Change the precision setting, then use the arrow to replace the current values.
Steve
Expert Elite Alumnus
Rail Community
Ā
Ā
