<Peter Funk - Autodesk>; "Inc." <
href="mailto:peter.funk@autodesk.com">peter.funk@autodesk.com> wrote in
message
href="news:6133970@discussion.autodesk.com">news:6133970@discussion.autodesk.com...
Erik,
The files created in UK English will work just
fine in the US English version. You do need to make sure that you are using
the same template and "Codes" files as your collegues so that you have a
consistant set of drawings as far as layers and styles. If you and your
collegues use the Norwegian "Country Kit" you should be fine.
Peter Funk
Autodesk,
Inc.
