New Member
kevincahir
Message 1 of 3 (136 Views)
Changing Individual Marker Sizes
136 Views, 2 Replies
10-22-2013 08:46 AM
I am trying to change the sizes of markers individually. When I change the marker of one, it changes for all of them. I think this has to do with the point groups. I am able to add all points to a new group  but I cant specify which markers i want in that group.
Any help?
Thanks in advance
troma
Message 2 of 3 (130 Views)
Re: Changing Individual Marker Sizes
10-22-2013 09:48 AM in reply to: kevincahir
If you edit a style, all objects which use that style will update.  It's like changing the colour of a layer; all objects on that layer will update (presuming colour is 'ByLayer'...).
The solution may be to copy the style, and edit the copy as you need to.
And yes, you can use a point group to override a style.  Set the style you want on the 'information' tab, and check off the appropriate box on the 'overrides' tab.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Active Contributor
wetsnow13
Message 3 of 3 (117 Views)
10-22-2013 10:15 AM in reply to: kevincahir
From a survey standpoint I recommend creating as many different point styles as you need, including for size.  You can then create field codes in the description key to handle them automatically.  You also don't have to worry about the hierarchy of your point groups for displaying styles.  I use point style group overrides for drafting, but always clear them out afterwards.
If you are doing this for trees or something "scalable" you can a scaling parameter in your desc key and have only one point style.
