Civil 3D Forum
Changing Corridor Target Surface
3 REPLIES 3
1594 Views, 3 Replies
Is there a method for globally changing the target surface for several corridors.  My existing surface has been revised and I had to create a new one as opposed to editing the original.  Now I have to associate my profiles, corridors, and section views to this revised existing surface.
Thanks in advance...
3 REPLIES 3
ccoles
Not that I'm aware of. But, I have been sucessful taking my original surface and updating it to new revisions so such a task is not necessary. One method that comes to mind is to remove all the definitions (points, breaklines, contours, objects, and edits) of the original surface, then pasting the new surface into it so the referenced surface is the revised surface.
Windows 7 64-bit
Dell Precision T5610, Dual-Xeon 2.6Ghz, 16 Gig RAM
Civil 3D 2013
in reply to: ccoles
Thanks ccoles,
That was my first choice but since we and to keep the original surface and profiles, corridors created with that surface intact, I choose to do a saveas and then edit. That was probably my first mistake in keeping this simple.
Kundertk
This is one of the reasons why I like to create a composite existing ground surface and use that for the project, even if I expect there will not be more than one source of survey information.  I call it something generic, like OG_Composite.
I'll create a new surface and paste it into the topo survey surface, then add the composite to the data shortcuts.  Always reference the composite surface for profiles, corridors, sections, etc.  This way, you never have to do a whole bunch of reworking if you end up adding additional survey during the lifetime of the project.  If new data ends up being required because of a scope change, missing survey or whatever other reason, then simply paste the new data into the composite surface drawing.
Rail Community
