For a school project we were given a dwg file that had already had all of the contours breaklines and linework etc done for us and have to design a road. After I designed a roadway corridor and new surface for it I am trying to see the updated contour lines and surface but they do not show up it just shows the line work for the roads curbs sidewalk etc. When given the orginal file there is no point groups or surfaces or anything in the toolspace. Any help or suggestions on how to get contours to show up and update and possibly get back to orginal points would be appreciated.
If you want to see a finished grade surface with a combination of the existing and corridor surfaces then I don't see any reason why you would want to extract the points etc.
Create a new empty surface. Paste the existing surface into it, then paste the corridor top surface in. The result should be what you're looking for.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
That statement has me scratching my head.
Bill
After re-reading the OP now I'm somewhat confused too. If you only have contours then you don't have an original surface. You may be able to recreate in from those contours and then use the solution I posted earlier.
Steve
