dpa-ig
Message 1 of 10 (3,668 Views)
Change template by another in the drawing
3668 Views, 9 Replies
02-14-2012 04:11 AM
I have a drawing what have  a template by defect, and i would  change the original template by another in the same drawing.
Are there a way to do this?
Thanks in advance.
To copy styles from a template file to another drawing
  1. On the Setting tab of Toolspace, expand Point Collection > Point Styles.
  2. Edit one of the listed styles.
  3. Click the Marker tab.
  4. Click Use AutoCAD BLOCK Symbol for Marker.
  5. Right-click in the Block list. Click Browse.
  6. In the Browse to File dialog box, select *.dwt from the Files of Type drop-down menu, and browse to your template file.
  7. Select the template file, and click Open.
  8. Click OK.
Any style that is not contained in the current drawing will be copied from the template.
That tip has been around since 2006.... super-secret-style-getter .... so it should work in 2009.
arturopolanco
Message 2 of 10 (3,666 Views)
Re: Change template by another in the drawing
02-14-2012 04:52 AM in reply to: dpa-ig
  8. Click OK.
Joe-Bouza
Message 3 of 10 (3,658 Views)
02-14-2012 05:13 AM in reply to: arturopolanco
Major Kudos Arturo! Thats an amazing work around
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
arturopolanco
Message 4 of 10 (3,656 Views)
02-14-2012 05:22 AM in reply to: Joe-Bouza
thanks
Distinguished Mentor
JeffPaulsen
Message 5 of 10 (3,645 Views)
02-14-2012 06:04 AM in reply to: arturopolanco
Nice tip. Does it only work in C3D 2012? I tried it in 2009 and it didn't work but it definitely works in 2012.
Jeff Paulsen
Civil 3D 2012 SP3 | Win 7 64-bit SP1
Xeon E5-1620 @ 3.60GHz, 16GB Ram | NVidia Quadro 600
Jeff_M
Message 6 of 10 (3,632 Views)
02-14-2012 06:31 AM in reply to: JeffPaulsen
JeffPaulsen
Message 7 of 10 (3,620 Views)
02-14-2012 07:12 AM in reply to: Jeff_M
I guess I it does work in 2009; however, you have to be patient.
I started it at home and did not see any styles added to the drawing. When I got in the office all the styles were there. I just started the process again and have been waiting 10 minutes and still do not see the point styles.
Jeff Paulsen
Valued Mentor
david.zavislan
Message 8 of 10 (3,576 Views)
02-15-2012 08:21 AM in reply to: arturopolanco
That seems like a lot of extra steps.  Here is how we have been doing this:
  1. Create a drawing from the dwt.
  2. Insert drawing as a block.
This will copy any styles that do not already exist in the current drawing.  It will not overwrite existing styles.  There are also some instances where expressions do not get copied correctly.
We have a library of style drawings that can be used to drag-and-drop sets of styles into a Civil 3D drawing as needed.
David Zavislan, P.E. | Wood Rodgers, Inc.
Valued Contributor
amar_mann
Message 9 of 10 (3,138 Views)
11-19-2012 02:41 PM in reply to: arturopolanco
Something somewhat related to this post. I mistakely opened my template in student version. It had years of my work. And now I can not import the styles and settigns etc from it to the full version . I tried using the method you just advised (Autocad block for point marker) and also tried to import all the styles from Manage>Styles>Import. Nothing works. Any help would be appreciated
JeffPaulsen
Message 10 of 10 (3,129 Views)
11-19-2012 04:32 PM in reply to: amar_mann
Find the last drawing you created using the template,erase everything out of it and save it as a dwt.
Keep a back up of your template in case this happens again.
Jeff Paulsen
