Civil 3D Forum
Change source file & path in Data Shortcuts Editor
6 REPLIES 6
troma
1956 Views, 6 Replies
I need to update both the path and the Source file name in Data Shortcuts editor.  If I update the path, it looks in the new path for the old file name, and throws an error.  If I update the File name, it looks in the old path for the new file name, and throws the same error.  Any way past this?
Thanks.
Mark Green
Working on Civil 3D in Canada
6 REPLIES 6
troma
in reply to: troma
BTW working in 2011 if that's relevant.
Mark Green
jmayo-EE
in reply to: troma
"Invalid Source File"
I would probably start with Recover and try again...no idea with this otherwise.
John Mayo
troma
in reply to: jmayo-EE
"Invalid" means it can't find it. There's nothing wrong with the drawings.
The error comes from looking in the old file path for the new file name, or looking in the new file path for the old file name.
Mark Green
Jeff_M
in reply to: troma
OK, it's working in 2011 but you didn't say which version isn't working.
Edit...nevermind, I reread your message. You ARE working in 2011 and that's where it's not...it's early, give me a break 🙂
Jeff_M, also a frequent Swamper
troma
in reply to: Jeff_M
That's what happens when I omit the pronoun. My bad 😉
Mark Green
troma
I've got past the problem.
What I did was rename the files to their old name. Then point the path in the data shortcuts editor. Then I renamed the files back to their new names. Then update the file name in the data shortcuts editor.
It feels like a hack, but it got the job done.
Mark Green
Rail Community
