Is there any way to change the referenced surface on a Surface Elevation Label.
I can see the surface in the properties but cannot change it.
C3D 2011
No. But, if you have a huge number of labels you need to change, one way to do this is to remove all of the data used to create the surface the labels are on, then paste in the correct surface. Of course, this won't work if you still need that surface.
