McLoughlin,
Here's how to set Label Styles from Top Down:
http://cadapult-software.com/label-styles-in-civil-3d-from-the-top-down-2/
Dave
Dave Stoll
Las Vegas, Nevada
McLoughlin,
How about making two copies of the All Points Group using your two styles, and then put either one at the top of the list to change the display.
Dave
Dave Stoll
Las Vegas, Nevada
Make a new point group at the top of the list, put those two points in that group (irrespective if they are in another group) and fix the style.
Points display based on a hieracy in the following order: applied point styles, group assigned styles, drawing default styles.
You can control the point style with groups as mentioned in the above posts or you can select the points and manually apply the style you want in the properties window. If styles have been applied manually and you want the styles defineds groups to control, select the points and change the styles to default.
