Active Member
2 Kudos
Post 1 of 4
Change of Station Label Format
701 Views, 3 Replies
11-16-2012 10:05 AM
I would like to change the station label format from 00+000.000 to 00,0+00.000
To move the + is easy, but how can I add the ,?
This type of station label is the standard by the Deutsche Bahn, so it's not that far-fetched.
thx.
Christoph
Win7 64bit
HP z400 Workstation
ATI FirePro V4800
C3D2013
It won't work with the digit grouping option - This Option is not available for Station-Formats.
I solved the Issue then via:
1. Create a new Expression "00,0": Rounddown(Stationvalue,-3)/1000
2. Adress this into your Styles: "00,0" "Station-Index-Sign" "Station Index left side of the Station-Index sign.
Thx.
485 Kudos
Post 2 of 4
Re: Change of Station Label Format
11-16-2012 10:14 AM in reply to: office
You could add a text component containing the comma and position it between the digits. However. I can't think of any way to create a space. So it would look pretty clumsy. See http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Line-Bearing-Label-Expressions/m-p/3701176#U3701176
Allen
264 Kudos
Post 3 of 4
11-16-2012 10:35 AM in reply to: office
Active Member
2 Kudos
Post 4 of 4
11-18-2012 11:10 PM in reply to: troma
Thx.
Win7 64bit
HP z400 Workstation
ATI FirePro V4800
C3D2013
