I am tring to change the label visibility of a point label style ,not sure it can be done, I search around for a bit I can seem to find anything useful....
you should be able to control the visibility right in the style. You could toggle the visibility off in the style, or write another style to apply to the points you want to affect if it is a subset of the points currently using the style in question.
I need it to turn the visibility off using code. I am able to change the style into another one,but the style I have only apply to a few computers.
