I use civil 2012, and have a drawing with over 400 attribute blocks that are all set to be "green" in the enhanced attribute editor, properties tab. I would like for all of the attributes to be set to "by layer". However, I find that the it only allows me to change one block at a time. As said earllier, I have over 400 blocks. Is there a quick way to change this? Thanks.
Solved by mathewkol. Go to Solution.
