Civil 3D Forum
change enhanced attribute property for multiple blocks
3 REPLIES 3
11751 Views, 3 Replies
I use civil 2012, and have a drawing with over 400 attribute blocks that are all set to be "green" in the enhanced attribute editor, properties tab. I would like for all of the attributes to be set to "by layer". However, I find that the it only allows me to change one block at a time. As said earllier, I have over 400 blocks. Is there a quick way to change this? Thanks.
3 REPLIES 3
mathewkol
How about editing the block definition and changing them to bylayer. Then use attsync.
Beware, if you have any other edits to other attributes including moving them, these edits will revert to the originally defined property.
Matt Kolberg
SolidCAD Professional Services
http://www.solidcad.ca /
in reply to: mathewkol
Worked like a charm! Thanks
du42TEH6V
Thanks!
Rail Community
