Civil 3D Forum
Change Codes for Corridor Section Points Report
4 REPLIES 4
dbussie
315 Views, 4 Replies
I would like to have my corridor section points report to have different labels for the points like Edge of Shoulder or EOP instead of labels like P2 and Hinge.  Is the only way to do this to somehow change the codes in the stock subassemblies?  If so, how do I do that?
Thank you in advance for your help!
Desirea Bussie
FBL & Associates
Civil 3D 2014
4 REPLIES 4
sboon
in reply to: dbussie
You cannot change the codes in the stock subs.  What you may be able to do is attach MarkPoinjt subassemblies to the locations you want to label, and add the required codes that way.
Steve
Please use the Accept as Solution or Kudo buttons when appropriate
Steve
Expert Elite Alumnus
dbussie
in reply to: sboon
Mark point wil allow me to add a code to it?  Just the mark point that is on the tool palette, right?
dbussie
in reply to: sboon
Okay, I've added the Marked Points with the codes I wanted but the Corridor Section Points Report that I've been running doesn't use them.  Is there another report that I can use to get the same info?  Or, is there a way to make that report include them?
dbussie
in reply to: sboon
Please disregard my last comments.  I realized I hadn't rebuilt my corridor.  Your suggestion worked perfectly!  Thank you so much!
Rail Community
