Civil 3D Forum
Change all text to Caps
15 REPLIES 15
Message 1 of 16
Kyle-Evans
83794 Views, 15 Replies
Hey guys I have over 1500 pieces of text in lowercase letter and I want to make them all uppercase.
Is there a easy and quick way to do this?
Thanks!
15 REPLIES 15
Message 2 of 16
justin.ziemba
in reply to: Kyle-Evans
Sorry, but there is no native way to do this with multiple objects at the same time.
However, I would suggest posting this on the AutoCAD forums, as there may be someone over that that has created a custom LISP or something to do what you are looking for.  Similar topics have been covered in the past, so that is probably your best route.
Justin Ziemba
Manager, Customer Support Services
Message 3 of 16
Looks like there is an Express Tool for it under Modify Text.
Message 4 of 16
Jeff_M
Express Tools TCASE
Message 5 of 16
And it works on multiple objects.
Christopher
http://blog.civil3dreminders.com/
Message 6 of 16
Kyle-Evans
in reply to: Jeff_M
Saweet!!!
Thanks Guys. You know more then the AutoDesk employees!!!!
Haha
Message 7 of 16
justin.ziemba
Wow, I totally missed that one.  Thanks for pointing it out!
Justin Ziemba
Message 8 of 16
Joe-Bouza
in reply to: justin.ziemba
Bing a Civil3d forum and you being a Civil3d specialist I can understand why you thought what you though Smiley Very Happy We wont pick on you
Your Name
Your Name
Message 9 of 16
pawan_141287
Highlight the text, hold down "shift" "ctrl" and press "u" and "l". this should change the text to upper or lower case.
Message 10 of 16
Jason-Cad-123
I have noticed that Revit 2017 new text editor will not convert existing caps text to lower case text. And it will only convert existing lower caps to upper caps.
Message 11 of 16
nonbeard13
in reply to: Jason-Cad-123
i like to use the Mtext - change to upper case for changing text to caps.
Message 12 of 16
It can be done through EXPRESS tools.
Go to:
Express->Text->Change Text Case->(Select your choice viz. UPPER CASE/ lower case etc and press OK)
That's it
-bsrinivas, email: bsrinivas2006@yahoo.com
Message 13 of 16
drpierce
In Revit 2017 there is a way. Go to the text and double clock to edit. In the tool bar there will be a lower case a with an arrow to upper case A highlight the text to make upper case and clock the button.
Message 14 of 16
arizsidd
in reply to: drpierce
this is the great way to change text case to caps by using online controls. it is very light
convert case
Tags (2)
Message 15 of 16
acameron75sh
DOUBLE CLICK ON YOU TEXT, SELECT ALL, Ctrl+Shift+u
Message 16 of 16
andrei.albu
There's a quick and easy Dynamo script that can do that for you
https://www.youtube.com/watch?v=8EX8_mzO2fg
Don't forget to subscribe In this video, I explain * How To Change Text Annotation Lowercase To Uppercase In Revit By Using Dynamo #Dynamo #Revit #bim #Autodesk #Dynamobim #eLearning #Revit2021 #BIM #Autodesk #whatsnew #newfeaturesinrevit2021 #BuildingInformationModeling #RevitArchitecture2021 ...
Rail Community
