Hello Everyone,
Topic: Pressure Pipe Networks
Question: Anyone familiar with a way to MERGE pressure pipe networks together
Example: Two different areas of a project site require a city water line. After creating two networks, can you combine the two in toolspace in order to use one label style for all city water lines?
Along the same lines, for Pipe Networks, you can go to Modify > Pipe Network > Merge, although we do not see that command for Pressure Networks
Any help would be greatly appreciated,
Currently, there is no option to merge your pressure networks together and I don't know of any way, other then deleting and recreating, to get pipes from one pressure network into another. Hopefully someone will prove me wrong.
