Civil 3D Forum
Challenge ~ Civil 3D Labels
7 REPLIES 7
Message 1 of 8
905298043
650 Views, 7 Replies
Good morning everyone,
Looking for some wisdom,
Topic:  Pressure Pipe Networks
Goal:  Set up labels for an entire network by adding a label style
Label Style:  Top of Pipe at each fitting (Essentially the starting and ending Outside Crown Elevations)
Challenge:
Looking for the best method to label the TOP at each end
Having difficulty editing the label style to add the labels at the end of the pipes rather than the middle of the pipe
In this case, I have to move each label indivually to the end of the pipe
Tried to add fitting labels and have been unable to figure out how
The project is a huge pipe network and I'm looking for a best approach
Any wisdom will be greatly appreciated
7 REPLIES 7
Message 2 of 8
Bill_Myron
in reply to: 905298043
Add a Flow Direction Arrow to your pipe label style. Set the visibility to false.
Create an expression and apply it to the rotation of the arrow. "IF(-{Pipe Slope}<0,0,pi)"
Anchor the Start Crown Elevation to the Start of the arrow.
Anchor the End Crown Elevation to the End of the arrow.
Add label to entire network plan.
Message 3 of 8
905298043
in reply to: Bill_Myron
Bill,
Thank you for the insight
Do we create the expression within Toolspace > Settings > Pressure Pipe > Label Styles > Expressions > New
Then enter "IF(-{Pipe Slope}<0,0,pi)" as the expression and Format the result as "rotation"
From there, do we create a new pressure pipe label style?
In the Label style > Layout > Component > add Flow direction arrow
Then select the pressure pipe text component > Anchor component > Anchor point > Start
Then select Flow direction arrow component > Visibility > False
From there, how do we apply the expression to the rotation of the arrow?
I appreciate the wisdom
Message 4 of 8
Bill_Myron
Enter the expression as Double. Under Pressure Pipe > Label Styles
In the label style, add the direction arrow and apply the expression to the rotation. There will be a drop down where you can select your expression.
Make sure fixed length is false, and change the minimum length to the shortest pipe length if needed.
Message 5 of 8
905298043
Bill,
Thank you for leading the way.  This will be key for a New York City project the firm is working on.
I appreciate the help
Message 6 of 8
905298043
Bill,
Another question when you have an opportunity to shed some light
Background:  Have designed with Civil 3D 2012 since recently graduating from Virginia Tech, learning the ropes for 2014 on the fly in my first job
Question:  When creating new pressure networks, is there a way to control the Top of Pipe Crown Elevation as you go pipe segment to pipe segment
At this point, when you enter the insertion elevation it becomes the centerline of the pipes and fittings
After laying out the network, do we have to go through pipe properties to adjust the starting and ending outside crown elevation of each pipe?
Can we adjust the elevation as go, when first creating the network?
Can the invert evelation, or crown elevation be a reference to go by (rather than the centerline) when laying the pipe?
Message 7 of 8
905298043
Bill,
* Also, looking back to our conversation on label styles ..  Is there a way to only label pipes of a certain length?  Fore example, if there are short pipe segments of the same material lined connsecutively and we only want to label long sections of the pipe
Message 8 of 8
dtdandy
I've followed your steps but am getting 0.00 as top elevation. Can you break down the steps for me.
Andy W.
Civil 3d 2016
Rail Community
