Hi all,
at roundabout, chainage at centeral alignment is connected to main roads alignments as it should be. problem is sometimes it is continuous chainage and some time it shows -ve chainages and sometimes it starts from 0+000.00. any suggestion how to fix that.
i want it should start from 0+000.00.
see attached screen shots for reference.
thanks.
you can assign the start chainage as 0+000 in the alignment naming pop-up box.
1. making alignment from Polyline:
a. Go to Alignment menu------Alignment from Polyline-----Select the Polyline and press enter----- a pop-up box will appear. In that you can give the name of the alignment and also you can assign any design creteria file if you have and see the attached image file for further details.
correct. these steps may follow when you are creating from scratch.
my query was: i created one roundabout, its centeral alignment is connected with road alignment. thats a way it should be. now the chainage on roundabout are continuty of road alignment and some time it is showing -ve chainages.
i want roundabout chainages must start from 0+00.000.
see attached screen shots.
see attached image file and change the start station in alignment propoerties
i have created a profile for centeral alignment (roundabout). what about the other two alignments mean entry/exit. i have to create seperate profiles for that. i was asuming it shoud linked with the main centeral alignment. any suggestion on that.
thanks.
You need to design the ICD profile and the entry and exit alignment profiles. The entry and exit alignments should tie in at start and end of the two central alignments like North side & East Side. You need to design ICD, entry and exit profiles and when you run corridor from ICD & central alignment, you targets will br exit and entry alignment profiles.
Hope this helps.
Reddy
