Dear Friends,
as we know civil 3d toolbox is a very good tool used to get digital data of Civil 3d features. Now i want corridore toe point (catchpoints) distances from centerline in tabular form. The reason i need this data is to define my R.O.W limit. in my case R.O.W is either 25m L/R or Catchpoint + 7m (left side) and catchpoint+13m (Right side) wichi ever is greater. so if i can get catchpoint distances in tabular form (excel) than i can apply if condition in excel and calculate R.O.W on either side at each station.
Further if any alternate solution is there please let me help.
Regards
Asad
Solved by klugb. Go to Solution.
Have you tried using the "Daylight Line Report"?
It will give you what you want and you can delete out what you don't want. You can save the output directly to excel also.
