Flow segment label using total Flow Type travel time for each segment:
Hi Fred,
Can you provide us more information on the issue and if necessary your drawing? Also, did you try editing your Label Style and see if you can remove Time component from label.
Hi Almas,
Yes I can remove the label, but I don't want to...
I want it to correctly label the two flow segments with 1.68 min and 0.45 min.
I have attached the file.
I see what you are saying now. By researching I found that this is already reported to development.
Thanks. How long ago was this reported?
