Civil 3D Forum
Catchment - Flow path segments travel time inot labeled correctly
4 REPLIES 4
fcernst
357 Views, 4 Replies
Flow segment label using total Flow Type travel time for each segment:
Fred Ernst, PE
C3D 2024
Ernst Engineering
www.ernstengineering.com
4 REPLIES 4
AlmasSuljevic
in reply to: fcernst
Hi Fred,
Can you provide us more information on the issue and if necessary your drawing? Also, did you try editing your Label Style and see if you can remove Time component from label.
Almas Suljevic
Product Support Specialist
Autodesk Global Subscription and Support
Autodesk, Inc.
Please click on "Accept as Solution" if post helped you resolve the issue.
fcernst
in reply to: AlmasSuljevic
Hi Almas,
Yes I can remove the label, but I don't want to...
I want it to correctly label the two flow segments with 1.68 min and 0.45 min.
I have attached the file.
Fred Ernst, PE
C3D 2024
Ernst Engineering
AlmasSuljevic
I see what you are saying now. By researching I found that this is already reported to development.
Almas Suljevic
Autodesk, Inc.
fcernst
Thanks. How long ago was this reported?
Fred Ernst, PE
C3D 2024
Ernst Engineering
Rail Community
