el_nath
Message 1 of 5 (421 Views)
Catchment Area Enhancements
421 Views, 4 Replies
11-15-2012 06:30 PM
I wish to have the ability to define runoff coefficient regions of a surface (using parcels, closed polylines, aecpolygons, mpolygons, etc...) such that when a catchment area is created, the weighted runoff coefficient is calculated. For a corridor surface, the runoff coefficient can be specified by the link code used to define the surface (defined in the code set style).
These surface coefficients should continue through pasting operations, i.e. a final design surface should have the runoff coefficents from the various corridor and grading surfaces used to define it.
Currently, I have to manually calculate the weighted runoff coefficient by first determining grass, aphalt, roof, areas per each catchment area.
Nathan Selles-Alvarez, P.E.
Senior Civil Engineer
Active Contributor
cpennetti
Message 2 of 5 (407 Views)
Re: Catchment Area Enhancements
11-15-2012 09:30 PM in reply to: el_nath
I think that would be a huge help as well. Some sort of cover condition could go a long way I'm Civil 3D to adding intelligence to the model, including assigning cover parameters to surfaces... that would really start to make it more of a "BIM" system
Valued Mentor
fcernst
Message 3 of 5 (386 Views)
11-16-2012 05:33 AM in reply to: cpennetti
Yes, along with %impervious, SCS curve numbers, N-imperv/Perv and D-Store Imperv/Perv.
Multipurpose these defined surface areas: There should be an additional database field for surface material thickness that can be used to define the subgrade datum for earthwork calculations.
Fred Ernst, PE
C3D 2015
Ernst Engineering
www.ernstengineering.com
LisaPohlmeyer
Message 4 of 5 (384 Views)
11-16-2012 05:42 AM in reply to: el_nath
All of you should post this to the Wishes discussion group!  Also, on the AUGI wish list.
Lisa Pohlmeyer
C3D 2012 SP4, C3D 2015
Please use "Accept as Solution" if this solved your issue.
el_nath
Message 5 of 5 (377 Views)
11-16-2012 06:21 AM in reply to: el_nath
You know I thought I did post this on the wish list. My bad (and working far too late!)
