Is there a conversion utility that will properly convert
SS,OP6,FP1000,AR262.4344,ZE89.3752,SD75.820,--B EP
SS,OP6,FP1001,AR254.1333,ZE89.2249,SD40.960,--EP BC
SS,OP6,FP1002,AR241.2550,ZE88.5809,SD33.000,--EP
SS,OP6,FP1003,AR225.3122,ZE88.0643,SD33.940,--EP EC
SS,OP6,FP1004,AR203.5448,ZE86.0816,SD58.300,--E EP
into
F1 VA 1000 262.4344 75.820 89.3752 "EP B"
F1 VA 1001 254.1333 40.960 89.2249 "EP BC"
F1 VA 1002 241.2550 33.000 88.5809 "EP"
F1 VA 1003 225.3122 33.940 88.0643 "EP EC"
F1 VA 1004 203.5448 58.300 86.0816 "EP E"
Have you tried the Survey Data Link in Civil 3D? If so, there is a free utility called Stringer Connect that works great.
I appreciate the response. Survey link generates the following,
SS,OP4,FP1293,AR225.2856,ZE90.4657,SD94.280,--EP BC
SS,OP4,FP1294,AR223.5327,ZE90.4935,SD94.200,--EP
SS,OP4,FP1295,AR222.2136,ZE90.5205,SD94.620,--EP EC
SS,OP4,FP1296,AR214.3427,ZE90.5851,SD101.020,--EP
SS,OP4,FP1297,AR208.4336,ZE90.5844,SD109.220,--EP
SS,OP4,FP1298,AR208.3715,ZE91.0013,SD112.760,--EP
SS,OP4,FP1299,AR213.0912,ZE91.0525,SD114.840,--E EP
I woudl prefer
SS,OP4,FP1299,AR213.0912,ZE91.0525,SD114.840,--EP E
I am having issues with survey figures and the second format works best with Auto-generated figures. Survey Link also strips out SET collection in the conversions, leaving only prism heights. I have been back and forth with Autodesk and as Survey Link was licensed to them ten years ago by TDS they are of no assistance.
Thanks for the assistance.
Have survey link create ascii file (TDS Sequential) from the raw file.
Also with the EC (end curve) code you'll have to use the BC (begin curve) that's just how it works
Rick Jackson
Survey CAD Technician VI
