Member
carlosbazalarcastillo
Message 1 of 7 (6,883 Views)
carlos b
6883 Views, 6 Replies
12-12-2012 07:05 AM
donde puedo descargar el subassembly composer para autocad civil 2012
tcorey
Message 2 of 7 (6,849 Views)
Re: carlos b
12-12-2012 11:01 AM in reply to: carlosbazalarcastillo
Desde el Centro de suscripciones de Autodesk.
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Joe-Bouza
Message 3 of 7 (6,829 Views)
Re: carlos b
12-12-2012 01:41 PM in reply to: tcorey
Impressive :smileywink:
Thank you
Joseph D. Bouza, P.E. (one of 'THOSE' People) Civil 3D 2012 & 2013
HP Z210 Workstation
Intel Xeon CPU E31240 @ 3.30 Hz
12 GB Ram
Note: Its all Resistentialism, so keep calm and carry on
64 Bit Win7 OS
antoniovinci
Message 4 of 7 (6,808 Views)
Re: carlos b
12-13-2012 01:23 AM in reply to: Joe-Bouza
Yup, 'cause a true V.A.R. must be polyglot !
Funny is that el señor Carlos named this topis as... himself.
tcorey
Message 5 of 7 (6,788 Views)
Re: carlos b
12-13-2012 09:17 AM in reply to: antoniovinci
Google Translate makes us all polyglots (which I looked up on Bing so I would know what you're calling me!)
Tim Corey, Owner
Redding, CA
Member
Message 6 of 7 (56 Views)
Re: carlos b
07-14-2014 11:30 AM in reply to: tcorey
he logrado instalar el C3D_SubassemblyComposer_SupportPack_x64 on autodesk civil 2012 pero cuando busco el prohgrama no lo encuentro y si voy al desisntalador de programas lo logro ubicar (imagen "a") a.png per cuando lo busco en la ubicacion que deberia estar no lo ubico (imagen "b"), me es util ya que en mi pasi trabajan con el civil 2012 pero nopuedo hacer que, hacer que funcione en mi maquina, el window que tengo es windows 7 professional...les agradeceria me puedan ayudar , no me sale ningun mensaje de error al instalar y apoarece que ha sido instalado correctamenteb.png
MarySeufert
Message 7 of 7 (45 Views)
Re: carlos b
07-15-2014 08:59 AM in reply to: carlosbazalarcastillo
In English: Have you tried the 'search programs and files' from windows start menu?
Another place to look is in Windows explorer. The file path to the program is 'C:\Program Files (x86)\Autodesk\Subassembly Composer 2012' Double pick the exe file.
En Español: ¿Has probado los "Buscar programas y archivos" desde el menú de inicio de Windows?
Otro lugar para buscar es en el explorador de Windows. La ruta del archivo para el programa es 'C: Archivos de programa \ (x86) \ Autodesk \ Subensamblaje Compositor 2012' Doble recoger el archivo exe.
_______________________________________________________________________
Normal people believe that if it ain't broke, don't fix it.
Software Engineers believe that if it ain't broke, it doesn't have enough features yet.
