Civil 3D Forum
Capturing the xyz of the PC, Mid, PT, BVCS, PVI, EVCS
10 REPLIES 10
Message 1 of 11
JamaL9722060
2080 Views, 10 Replies
Capturing the xyz of the PC, Mid, PT, BVCS, PVI, EVCS and stations of horizontal and vertical alignment,
I’m wondering if there IS ONE INTEGRATED COMMAND by which the xyz of PC, Mid, PT, BVCS, PVI, EVCS of horizontal and vertical alignments and stations can be captured (attached)
The “create points – alignment” can be used to get the xyz of the stations but it doesn’t included other points like PC, Mid, PT, BVCS, PVI, EVCS
Best
Jamal
Jamal Numan
10 REPLIES 10
Message 2 of 11
Joe-Bouza
in reply to: JamaL9722060
Have you considered the report tool box? It give lots of data regarding alignments? Lable styles or tables?
Your Name
Your Name
Message 3 of 11
Jay_B
The create profile geometry points on alignment will place points at bvc, evc etc.
http://docs.autodesk.com/CIV3D/2013/ENU/filesCUG/GUID-CC9DAE3C-1B0C-4141-98F5-CFE1CEF1ED71.htm
The create points at alignment geometry command will place horizontal curve points like pc, pt etc.
http://docs.autodesk.com/CIV3D/2013/ENU/filesCUG/GUID-1E28C908-AB54-4571-B06A-B536396C0E39.htm
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Message 4 of 11
JamaL9722060
in reply to: Jay_B
Thank you very much Jay_B and Joe-Bouzafor the help,
What I’m looking for is one integrated command by which the XYZ coordinates of the following points are summarized in a table (and then to be exported as CSV format)
  1. Stations
  2. Horizontal alignment: PC, Mid, PT,
  3. Vertical alignment: BVCS, PVI, EVCS
Is that possible?
Best
Jamal
Jamal Numan
Message 5 of 11
Joe-Bouza
Hello JamaL
There is no direct command I am aware of. An alignment and profile report will give you the data you seek. Running the COGO point will enable you to create a table easily. Either way you have to put in some work up front or on the back end
Your Name
Your Name
Message 6 of 11
Jay_B
Jamal,
I,m not aware of any one step integrated method to obtain ALL the information you'd like for the points.
If you create the cogo points using the 2 point commands I mentioned in my last post in addition to measure alignment command you've been using. This will create all of the cogo points you're sekking AFAIK. then some renumbering of the points may be required to get the desired order in the table. Create a point table if you desire as mentioned in your related post.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Inclusion-of-point-groups-in-a-table/td-p/4337074
Then export these cogo points to an ascii. file open in excel and format as desired.
I'm sure there are other ways to do this but I'm fairly certain all methods will involve multiple steps.
C3D 2018.1
C3D 2016 SP4
Message 7 of 11
JamaL9722060
in reply to: Jay_B
Thank you guys for the prompt help,
I’m not sure if the table can include the station number (for example 0+100) or the point name (like PC, Mid, PT, BVCS, PVI, EVCS) to better recognise what each point represents on the field (attached).
The “create cogo points from corridor” command sounds not to produce what I’m looking for
Best
Jamal
Jamal Numan
Message 8 of 11
Joe-Bouza
If you create points as previously suggested then a station offset report will give you that information.
Your Name
Your Name
Message 9 of 11
JamaL9722060
in reply to: Joe-Bouza
Reports have the same problem. No one report can include all the data I wanted.
  1. Stations
Also, I don’t know how to include the station number (for example: 0+100) and desertion (like PC, Mid, PT, BVCS, PVI, EVCS,…)
Best
Jamal
Jamal Numan
Message 10 of 11
_Hathaway
You will have to purchase Sincpac to be able to do what you want. We had similar issues. Sincpac paid for itself the first day we used it, it's a very powerful inexpensive Civil3d addon that can do everything you want + tons more.
Message 11 of 11
JamaL9722060
in reply to: _Hathaway
Many thanks mikehathaway2942 for the help,
Best
Jamal
Jamal Numan
Rail Community
