Capturing the xyz of the PC, Mid, PT, BVCS, PVI, EVCS and stations of horizontal and vertical alignment,
I’m wondering if there IS ONE INTEGRATED COMMAND by which the xyz of PC, Mid, PT, BVCS, PVI, EVCS of horizontal and vertical alignments and stations can be captured (attached)
The “create points – alignment” can be used to get the xyz of the stations but it doesn’t included other points like PC, Mid, PT, BVCS, PVI, EVCS
Best
Jamal
Joe Bouza
Thank you very much Jay_B and Joe-Bouzafor the help,
What I’m looking for is one integrated command by which the XYZ coordinates of the following points are summarized in a table (and then to be exported as CSV format)
Is that possible?
Best
Jamal
Joe Bouza
Thank you guys for the prompt help,
I’m not sure if the table can include the station number (for example 0+100) or the point name (like PC, Mid, PT, BVCS, PVI, EVCS) to better recognise what each point represents on the field (attached).
The “create cogo points from corridor” command sounds not to produce what I’m looking for
Best
Jamal
Joe Bouza
Reports have the same problem. No one report can include all the data I wanted.
Also, I don’t know how to include the station number (for example: 0+100) and desertion (like PC, Mid, PT, BVCS, PVI, EVCS,…)
Best
Jamal
Many thanks mikehathaway2942 for the help,
Best
Jamal
