Civil 3D Forum
CANT RECOVER FILE
11 REPLIES 11
Message 1 of 12
757 Views, 11 Replies
CANT RECOVER FILE
Good afternoon,
One of our customers cant recover or open this file, if one run the recover command the file size is 3k and not workable.
Do the Autodesk support team have a tool to maybe try and look at this, as the customer also cant find bak file on the system.
Best Regards,
Andre
11 REPLIES 11
Message 2 of 12
antoniovinci
Please upload here that DWG, in ZIP format.
Message 3 of 12
in reply to: antoniovinci
Hi there, the file is bigger than 1.5MB allowed on this site its 3MB so I will need ftp link or something. 🙂
Andre
Message 4 of 12
Alfred.NESWADBA
Have your customer knowledge about BAK-files? If not then describe it to him that the chance to get a previous state of the project does not get lost!
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 5 of 12
antoniovinci
Andre, please ZIP it, and send me by email to: antoniovinciMan Very Happywp.pl
Message 6 of 12
antoniovinci
Recovered as best as I could: you'll have to load again the 2 two missing XREF (Road Grids, 2011-10-13 vw building footprint).
Message 7 of 12
Thanks Antonio,
Looks much better than my attempt, did you open the file in Civil 3D as I see its DXF format and all the Civil 3D objects are missing and all 2D.  🙂
Thanks for the help.
Best Regards,
Andre
Message 8 of 12
dpa-ig
Hi, i like to know, how you do it...sometime i happen me the same problem....
Message 9 of 12
Jason.Hickey
in reply to: dpa-ig
I know it's hard to believe, but we don't have any magic tools that will open any file. Literally everything that we have is what is available to the general public. We do have a guide for troubleshooting corrupt drawings, which can be found here.
Jason Hickey
Premium Services Specialist
Message 10 of 12
AllenJessup
in reply to: Jason.Hickey
One tool I've used in the past where other methods have failed is Partial Open. I've done a Partial Open and opened the drawing Layer by Layer. If the problem is due damaged entities you may be able to recover all but one or two layers. INDEXCTL must be set to 2 of 3 for this to work.
I haven't used this method on a drawing with Civil 3D entities in it. So I can't say how this will work with them.
Allen
Allen Jessup
CAD Manager - Designer
Message 11 of 12
in reply to: AllenJessup
Hi guys,
Thanks for the replies and links, I tried the partialopen (set indexctl to 2 and 3), recover and recoverall, but no luck.
I cant search for the auto save file as this is for customer and most of the companies here closed for holidays.
If one try one of those commands it just crashes, recovers up to point then crash the software.
I also cant upload file because its too big 3MB, limit is 1.5MB.
Andre
Message 12 of 12
AllenJessup
Sorry I wasn't completely clear.  INDEXCTL must be set before the problem happened. IOW It has to be what you usually have as the default.
Allen
Allen Jessup
Rail Community
