Civil 3D Forum
Cant extract parcel names in data extraction
4 REPLIES 4
bcsurvey
319 Views, 4 Replies
I've become somewhat familiar with data extractions in the last few weeks.  However, I can't find a way to extract parcel names (i.e. what I name them in the properties window and what I see under the Name field in Parcel Properties).  I've chosen every attribute I can think to include, but they all result in "Parcel" instead of the specific parcel ID.  What am I missing?
Thank you
Civil 3D 2019 (6.1)
Windows 10 Pro (21H2)
(i7-11850H @ 2.50 GHz)
32GB RAM
NVIDIA RTX A2000
4 REPLIES 4
rl_jackson
in reply to: bcsurvey
Unfortuately there isn't that much you can do with parcels.
Short of labeling, dividing etc...
I have UDP's that even after they are made available, I can not import or export them, as you can with other things. Really disappointed that you can do things like the with map functions put can't in C3D.
Rick Jackson
Survey CAD Technician VI
bcsurvey
in reply to: rl_jackson
Wow, that's piss poor.  Parcels are at the heart of subdivision work, and extracting something as simple as the object name from something as basic as a parcel shouldn't be difficult, much less IMPOSSIBLE.  I began tinkering with adding the parcels to a site, which I hadn't done yet, to see if I could get the information from the site info.  But I haven't gotten very far with it.  I assume that you've tried going that route as well?
Civil 3D 2019 (6.1)
32GB RAM
NVIDIA RTX A2000
rl_jackson
Sure did, I got this great idea to but things like owner, address, deed ref, and parcel number in as a UDP so that use them in my parcel labels. It works well but then I hunted all around for a way to get the data out. Tried XML everything, I could think of with know luck. BTW Piss Poor is butting it mildly, down right neglect, for parcels.
Rick Jackson
KirkNoonan
You can copy all of that data directly from the prospector tab of the toolspace window and paste it into Word, Excel, etc. Depending on what you're trying to do, you can export the parcels to an SDF file, FDO connect to the SDF file and join that data table with your spreadsheet to get the information back into the drawing.
- Sorry, missed the part about the UDP's. If you generate that data in a CSV file, then it could be linked into the SDF data table.
Rail Community
