any good?
Where did the print plot DGgo?
Your Name
Your Name
Solved by Sinc. Go to Solution.
Solved by Jeff_M. Go to Solution.
http://forums.autodesk.com/t5/Printing-and-Plotting/bd-p/30
Thanks Sinc. People are having hardware issues with 64 bit w7? I ask because I'm faced with 32 or 64 upgrade. I guess its a no brainier to go 64.
Your Name
Your Name
Thanks Jeff. Pays to use the mouse on these web page thingys
Your Name
Your Name
@Sinc wrote:
I've heard a bunch of complaining from people using (or trying to use) HP printers on Windows 7 x64.
I have 4 Hp Printers/Plotters, I use Win7 x64, and the only issue I have is that my tabloid size printer thinks it has the wrong size paper when printing to Tabloid.....I can use a different driver which solves that problem, but it has other problems so I stay with having to press the button on the printer to ignore the 'wrong' sheet size....but this has been a problem with all 3 of the x64 OS's and this printer.
