Hi everyone,
I added geometry point label set, but all the text is rotated in upside down. The reverse label command seems not working. I tried to reverse text angle in its label composer, but it also does not work. I think the only way to do it is to redraw my alignment and change start and end point. So,does anyone know how to reverse alignment label?
Solved by kcobabe. Go to Solution.
Change the drawing Readability Bias. Sometimes the value of 110 just does not work.
