I have a drawing with a bunch of layers that cannot be deleted since they are nested in block definitions. However, the blocks are not in use and cannot be purged. I think it is because they are referenced for point styles, that are also not in use. Is there a way to delete the point style in order to clear these layers and blocks? Thanks.
As long as the Point Styles are not being used in your drawing, you can simply right-click on them in Toolspace -> Settings and delete them. (Note that you cannot do this if they are being used in a Description Key set... You'll need to delete the Desc Key set, or remove keys that use those Point Styles, before you can delete the Point Style. If you see a little orange triangle next to the Point Style name, this means something in your drawing - possibly just a Desc Key - is referencing that Point Style.)
