Win 7 64 bit PC
Disabled AV
I have installed the 64 bit version
Whenever I try to run it the acad.exe hangs around for about 5 seconds then dissapears.
Eventlog shows error:
Faulting application name: acad.exe, version: 25.0.55.0, time stamp: 0x4f309abd
Faulting module name: accore.dll, version: 19.0.55.1, time stamp: 0x4f399fb3
Exception code: 0xc0000005
Fault offset: 0x000000000004d980
Faulting process id: 0xec4
Faulting application start time: 0x01cef6c54bdbb0d6
Faulting application path: C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\acad.exe
Faulting module path: C:\Program Files\Autodesk\AutoCAD Civil 3D 2013\accore.dll
Report Id: 8a6f2130-62b8-11e3-aca0-6cf049732958
I have tried running a repair and a reinstall but this does not help. I also get the error 'adui19res.dll not found' when running a reinstall or repair.
Can anyone help me with this? I have sunk a lot of hours into it and I can only think to rebuild the PC.
