Civil 3D Forum
Cannot Delete Label Style from Settings Tab
3 REPLIES 3
297 Views, 3 Replies
There is a pipe label style in my model that I cannot delete. The glyph beside it says it is used in the dwg somewhere, but there are no child dependants to it and it is not used to label any pipes in my model. How can I determine what is referencing this style so I can delete it. Is there any way to "QSELECT" or filter by "LABEL STYLE"?
3 REPLIES 3
nzeeben
It is most likely one of the command setting defaults or rhw object defaults
that are using it. Assuming you dont think it is in use elsewhere. I would
check those first.
Nick
wrote in message news:5270909@discussion.autodesk.com...
I've eliminated the style from all the command settings now. But it is still not going away.
What do you mean by "rhw object defaults "? Message was edited by: Kelly-NDLEA
nzeeben
Apparently I was a row of keys off, should have read the object settings.
In the case of pipes, right click on pipe network in the settings tab and
adjust the feature settings. Bunch more style defaults contained there.
Nick
wrote in message news:5270967@discussion.autodesk.com...
Rail Community
