Cannot delete label style component. This is for line annotation labels.
I created a child BRG-ONLY from a BRG-DIST and it will not allow me to delete the distance component. The red X is faded and not clickable.
This is my second day with a new company, and when somebody else created a similar child style apparently they could not either. The just made the distance component invisible... which I guess works almost as well.
How would I be able to pick a specific component to make sure I can delete it?
Solved by Jeff_M. Go to Solution.
Could try Rt. clicking on those Styles in the Settings Tree and choose "Find References"
This will show where the Styles are "In use".
You cannot delete components of a child style which are defined in the Parent style. The whole idea of a Child style is to allow styles to have the same components but be able change the look of them... i.e.: The text comonent will always be in the style, but you can change the position, color, size, or the contents of the child. To be able to delete components, make a Copy of the style instead of a Child (or use the Visibilty property as you've done).
@Jeff_M wrote:You cannot delete components of a child style which are defined in the Parent style. The whole idea of a Child style is to allow styles to have the same components but be able change the look of them... i.e.: The text comonent will always be in the style, but you can change the position, color, size, or the contents of the child. To be able to delete components, make a Copy of the style instead of a Child (or use the Visibilty property as you've done).
That makes sense. Now, if it were me and my company, I would have simply created a new style, and not made a child. But, new job, new ways.
For my own edification: What is the purpose of having a child style vs a new distinct style? Do changes (i.e.: color, etc.) in the parent automatically filter down to the child styles? That would be handy, but other than that I'm not sure I see the point.
Mark Green
Working on Civil 3D in Canada
Mark Green
