Civil 3D Forum
cannot change wall thickess for rect junction structure NF
3 REPLIES 3
Hidden_Brain
713 Views, 3 Replies
the OOTB rectangular junction structure NF has a constant wall thickness of 6". when I try to change the parameter configuration to list instead of constant, the formulas using the wall thickness do not calculate anymore, and I get an error saying "One or more calculated values failed". does anyone have any suggestions how to make this work? please see attached images in order.
3 REPLIES 3
Hidden_Brain
in reply to: Hidden_Brain
Bump!!
Joe-Bouza
Did you ever get that figure out?
Joe Bouza
Unfortunately, you will need to edit the associated XML file to allow this type of change.  You can open this XML file with notepad.  I use Notepad++ as it allows for syntax coloring.
Anyway, once it is open in a text editor, scroll down to approximately line 50 to find the line listing "Wall Thickness".  At the beginning of this line, you need to change tag from ColumnConst to ColumnConstList.  You will also need to change the ColumnConst tag at the end of the line to ColumnConstList.  After the tags are modified, you will need to modify the specific sizes.
Currently 4.0000 is the only wall thickness available.  Delete this text.  Now add these lines (or change them up as desired):
		<Item id="i0">4.0000</Item>
		<Item id="i1">6.0000</Item>
		<Item id="i2">8.0000</Item>
Each item will need a new id value.  It appears it should be i0 with the 0 increasing for each item.
Once you are done, save the file.  You should then be able to open and edit this part in PartBuilder to verify validation.
Edit: You can change other constant items to lists with this method, such as adding various floor thicknesses to a structure.
Rail Community
