Active Member
0 Kudos
Post 1 of 12
Cannot change number of decimal places in elevation label
2852 Views, 11 Replies
05-07-2012 04:31 PM
The defaul label style for the Elevation of points is set to 3 decimal places. We are trying to change the elevation display to 2 decimal places. We have tried the directions in the following discussion: http://forums.autodesk.com/t5/AutoCAD-Civil-3D/How-to-change-the-number-of-decimal-places-of-the-ele...
Which is:
Toolspace
->Settings
-->Drawing name
--->Edit Drawing Settings
---->Ambient Settings
----->Elevation
------>Precision -> We modify from 3 to 2 decimal places.
It does not modify the display settings.
Also:
Toolspace
->Settings
-->Drawing
--->Point
---->Label Styles
----->(right-click) Edit label styles
------>Layout
------->Text
-------->Contents
--------->click on the "..." (three points) button
(Open "Text Component Editor - Contents"
--------->Select Point Elevation in the driop down list.
---------->Precision: Set to 0.01
------------>Ok, Apply, etc...
This does not seem to work either.
Any suggestions appreciated.
The second method is the one that will work.  You are probably forgetting to press the arrow button that applies the changes.  After you modify the precision you have to press the arrow that "applies" that change to the text field.  See attached image.
When you make the change in the point style did you hit the arrow in the upper as shown. If you did not it does not push the setting to the style.Precision.png
Valued Contributor
10 Kudos
Post 2 of 12
Re: Cannot change number of decimal places in elevation label
05-07-2012 05:30 PM in reply to: fjperez
Distinguished Mentor
101 Kudos
Post 3 of 12
05-07-2012 05:34 PM in reply to: fjperez
C3D12-13
Win7x64 6gb
Active Member
0 Kudos
Post 4 of 12
05-08-2012 07:06 AM in reply to: fjperez
This worked perfectly. Thanks!
Active Member
0 Kudos
Post 5 of 12
11-08-2014 02:57 AM in reply to: fjperez
Hi
Following the instructions above I find the precision is set to 3dp which is what I want. The drawing is still displaying to 2 dp. Is there another place I need to change this?
308 Kudos
Post 6 of 12
11-08-2014 07:00 AM in reply to: tomhoban
When you say, "the drawing is still displaying to 2 dp," do you mean your existing label style does not update when you change the precision in the label style editor? If you're setting it and remembering to press the arrow to move your settings to the preview window, as in the two solutions above, and then pressing OK all the way back out, maybe doing a Regen, and it's still not working....
Are you sure you're editing the correct label style?
BTW, the problem with forgetting to press the arrow to move the new precision settings over still gets me. I've been using Civil 3D since the first preview version, 2004, and I still forget to press that stupid button. I doesn't take as long to figure out what you did wrong after you've done it twenty times, but my forehead sure is getting flat from slapping it and saying, "Doh," all the time.
Tim
Tim Corey, Owner
Delta Engineering Systems
Redding, CA
Autodesk Authorized Value-Added Reseller
Active Member
0 Kudos
Post 7 of 12
11-08-2014 10:02 AM in reply to: tcorey
Thanks for the reply Tim. The thing that threw me was when I got to the text component editor (TCE) and seleted point elevation from the properties the precision was showing as .001 which was what I wanted so no need to change. However the displayed labels were to 2 dp (.01)
It wasn't until I selected the text in the black window of the TCE that I noticed the precision changed by itself to .01 so I guess some kind of refresh issue?
I also noticed that when resetting the precision and pressing th arrow it is impotant to ensure the old code in the black window is over written or deleted or a fairly mixed up label will occur.
So now my point elevations are displaying correctly. I had hoped that this would solve the main problem which is getting my point table to display to 3dp; it hasn't. Any ideas? I can not see anythingin Table Style editor.
Tom
Valued Contributor
10 Kudos
Post 8 of 12
11-08-2014 10:27 AM in reply to: tomhoban
Tried to reply once but didn't seem to work.
The easy way is probably for you to just click on your point table that you already created, then on the ribbon you should see "table properties", click on edit table style. Then click on all of that text below the "elevation" column. Then that same edit style window will appear and you can change the number of decimal places.
Don't forget to press the arrow.
Mark
Active Member
0 Kudos
Post 9 of 12
11-08-2014 10:30 AM in reply to: tomhoban
ok figured it out: double click the structure in data properties of the table style editor and as above.
135 Kudos
Post 10 of 12
11-08-2014 10:39 AM in reply to: tomhoban
Tom,
Here's a couple more places to look. Ambient Settings Tab in Drawing Settings:
Settings >> Point >> Commands >> AddPointTable >> Edit Command Settings:
Dave
Dave Stoll
Mohave Valley, Arizona
Intel Core i7-3820QM 3rd Generation Quad Core 2.7 GHZ CPU
16 GB DDR3 RAM ( 2 DIMM ) / 180 GB SSD
Nvidia GeForce 650M Graphics w/2 GB Memory
Windows 7 Professional 64 bit / AutoCAD Civil 3D 2014/2015
