Civil 3D Forum
Can you duplicate my layer glitch? C3D 2011
6 REPLIES 6
troma
256 Views, 6 Replies
Reposting here after trying the plain jane ACAD forum first.
In a drawing in C3D 2011, with various objects & layers.
Turn off a few layers.
Select a visable object, then Esc off to deselect.
Select a second object, and go to your layer toolbar.
Scroll to an off layer, turn it on, and select the layer to place your current object on that layer.
What happened?
For me, the second object I selected is forgotton, and the first object is placed on the selected layer.
Let me know.
Mark Green
Working on Civil 3D in Canada
6 REPLIES 6
ToddRogers-WPM
in reply to: troma
In your Options, Selection tab, turn on the Noun/Verb Selection.
Todd Rogers
troma
in reply to: ToddRogers-WPM
It is already on.
Thanks.
Mark Green
ToddRogers-WPM
in reply to: troma
You wouldn't happen to have Sketchbook installed do you?
Todd Rogers
troma
Hmm...never heard of it.  So I would guess not.
Mark Green
ToddRogers-WPM
in reply to: troma
OK.  We had a customer with a similar issue that had Sketchbook Designer installed.  Ok, next question....Are you using a legacy template file?  and does this happen with the template file straight out of the box?
Todd Rogers
troma
Well....the template I'm using had many settings migrated from 2008.  I'm not sure how this was done originally; whether it was opened and saved up, or if settings were dragged over from 2008.  The person who did it isn't here to ask right now.  So I'm not sure if that counts as a 'legacy' template.
But I don't think that's an issue, since it does the same on regular template.  I'm not sure where to find the Autodesk out-of-the-box template; I never use it.  But I found one of the tutorial templates, and it acted the same in there.
Next question please! Smiley Wink
Mark Green
Rail Community
