AutoCAD Civil 3D General Discussion
mikehathaway2942
Message 1 of 28 (4,206 Views)
Can't snap to point symbols
4206 Views, 27 Replies
02-24-2011 09:59 AM
For some reason we cannot snap to the node on several of our point symbols.  I cannot see anything different when compared to the other point symbols that we can snap too.  Basically if i try to draw a line of obtain a distance using the NOD osnap on these point symbols i get nothing, its like they dont have a NOD to snap too.
Any ideas? This is quite annoying.
Valued Mentor
Valued Mentor
sjg
Message 2 of 28 (4,203 Views)
Re: Can't snap to point symbols
02-24-2011 10:14 AM in reply to: mikehathaway2942
Open up your Transparent Command toolbar, there is an icon for point number.  Not sure if your familiar with transparent commands but they are to used with in a command say for drawings a polyline.  So if type PL to start polyline then type 'PN to activate the Point number transparent command.  Then you just type the point number or range if sequential you can also use commas for different point number sequence.
Example.
PL, 'PN, 1-4,6,9,10.  This one command will draw a polyline to each of those points.
Can also be used with 3DPL, lines, etc.
Steve Goessling
Land Consultants
Civil3D 2013
Windows 7, 64 bit
Intel i7 2600 @ 3.40Ghz
16 GB RAM
Nvidia Quadro 600
mikehathaway2942
Message 3 of 28 (4,196 Views)
02-24-2011 10:29 AM in reply to: sjg
Yes I'm aware of transparent commends and use them regulary and use the one you referred to in your post.  However, that was not the point of my question.  It's much easier to just keep the OSNAPS on that we need when running inquiries and things of that nature.  With that said, it's not working properly and not snapping to some of our blocks and we would like to know why.
Here's to wishing for a 'PO osnap that snaps to your point no matter where you click on the point or point label.
Active Contributor
wetsnow13
Message 4 of 28 (2,859 Views)
03-13-2013 12:28 PM in reply to: mikehathaway2942
Any help out there with this?  I just came across the same thing in a drawing - C3D 2012.  I've got quite a few wetland flags to connect.  If I switch to other point styles they all work fine for OSNAP NOD, just the wetland point style seems "broken".
*Expert Elite*
troma
Message 5 of 28 (2,848 Views)
03-13-2013 01:12 PM in reply to: wetsnow13
I've experienced this too, no idea why.
If you have all your points in a group you could use that to temporarily override their style, so you can snap to them
Credit where credit is due! Give kudos or accept as solution whenever you can.
Active Contributor
wetsnow13
Message 6 of 28 (2,829 Views)
03-14-2013 05:17 AM in reply to: mikehathaway2942
Thanks Troma,
I used the point object transparent command, but was just hoping that there was a solution/reason for the glitch.
*Expert Elite*
AllenJessup
Message 7 of 28 (2,828 Views)
03-14-2013 05:41 AM in reply to: wetsnow13
Is it a stock symbol or one you created yourself.
Allen Jessup
*Expert Elite*
troma
Message 8 of 28 (2,812 Views)
03-14-2013 09:29 AM in reply to: AllenJessup
For us it was a symbol using a block.
The block was a donut, with inside diameter zero, and ouside diameter of 0.01
Now I think of it, I should have been able to snap to 'Center'.  Don't know if I tried that.  It was a while ago.  I just know that I couldn't snap to 'Node'.
*Expert Elite*
AllenJessup
Message 9 of 28 (2,808 Views)
03-14-2013 09:55 AM in reply to: troma
There's no way I know of to include and Autocad point or custom marker style with a block within the style. I'd thing that if you use an AtuoCAD Block to the point marker. You'd have to include an AutoCAD Point in the block. You'd either need a point style that wont show it when plotted or make it a non-plotting color.
Allen Jessup
*Expert Elite*
troma
Message 10 of 28 (2,803 Views)
03-14-2013 10:52 AM in reply to: AllenJessup
Now, I thought all cogo points had a 'Node' snap simply by virtue of being cogo points. (And that these ones had something strange going on.) But you're saying that it depends entirely on the point style being used.
There you go, challenging my worldview and broadening my horizons again, Allen!
Announcements
Need installation help?
