Is it a bug ?
I can add data, and I see it onto my section views but I cant view it again in the dialog.
In example, I add a profile at 11 m. using markers and i see it. If I come back to the diaog to add or delete data realted I see nothing....
Any idea ?
Civil 3D (2013) how much you have to improve....
If your referring to the following Dialog being empty when accessed through Sample Line Group Properties or Section View Group Properties, this is normal behavior AFAIK.
Profile Grade information for a given section view can be viewed on the "Profile Grade Lines" Tab of the Section View Properties dialog.
Select a section view>Ribbon>Section Properties.
So... to change the whole properties of a multiple section views have I to ?
An then.... is this a bug...?
If something in the design changes where PGL's need to be reapplied to the section views it's very easy to delete them reapply them to the section views all at once.
I'm not sure if it should be considered a bug, it's been this way since C3d 2011 AFAIK.
It's just not intuitive, typical autodesk! Yes you cant see what has been added, but you know whats been added, so....
When in view group properties > profile grade. Select the alignment you want to remove - instead of hitting ADD, hit the RED CROSS. Then OK accept and they all remove. You don't have to do one by one.
