Civil 3D Forum
Can't open or recover dwg
5 REPLIES 5
kyle.nielissen
864 Views, 5 Replies
Yesterday I was working in this file and today it just goes to 43% and freezes my computer, bak file is doing the same. Any suggestions?
No luck with relavent previous drawings from my server.
https://forefronteng-my.sharepoint.com/personal/kyle_nielissen_forefronteng_ca/_layouts/15/guestacce...
5 REPLIES 5
tcorey
in reply to: kyle.nielissen
I tried a few things including Insert, MapQuery and Recover. Civil 3D locked up on all three. I hope your IT department has a server backup for you because this drawing appears to be dusted.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Jeff_M
Using plain AutoCAD 2014 to Recover the fie it opened almost immediately. It found, and fixed, a number of errors relating to PDF references.
Note that I had to use the 'real' plain AutoCAD from Infrastructure Design Suite and NOT the "Civil3d as Autocad" shortcut.
You can grab the recovered file here:
https://dl.dropboxusercontent.com/u/32148252/Sheets54-60247896-recovered.dwg
Jeff_M, also a frequent Swamper
tcorey
in reply to: Jeff_M
I didn't think of using vanilla AutoCAD. Good catch, Jeff.
BTW, what are you doing working on Sunday? You should be out golfing or something. 😉
Tim Corey
Redding, CA
Jeff_M
in reply to: tcorey
I was ill with the flu 3 days this week, Tim. Have a lot of catching up to do. Plus, it's hot today & I don't golf (silly game, chasing little white balls all over the place!) Not to mention how much fun I have chasing down bugs in Autodesk's and my own code while watching NASCAR! 🙂
kyle.nielissen
in reply to: Jeff_M
Thanks for the help thst worked great.
Rail Community
