Civil 3D Forum
Can't open DWG
16 REPLIES 16
Message 1 of 17
Vasily_BC
1189 Views, 16 Replies
Can't open DWG
Hi.
I received a drawing from one of our consultants and somehow can't open any version of it they've sent.
Already tried recovery and referencing.
I don't which version of Civil 3D they use but my is 2013.
However I can open it in DWG Viewer and Global Mapper.
Any ideas?
16 REPLIES 16
Message 2 of 17
antoniovinci
in reply to: Vasily_BC
You could try to open it in Autodesk Trueview, then convert to an older DWG release...
Message 3 of 17
AllenJessup
Are you getting any specific error about it not opening? Have you tried a Partial Open? Can you open it in Design Review?
Allen Jessup
Allen Jessup
CAD Manager - Designer
Message 4 of 17
Vasily_BC
in reply to: antoniovinci
Antonio, it worked! Thanks for all your replies that you've did.
Message 5 of 17
Vasily_BC
in reply to: AllenJessup
Only Antonio's suggestion helped.
Message 6 of 17
AllenJessup
Glad he could help you.
 Allen Jessup
Allen Jessup
Message 7 of 17
antoniovinci
I was only lucky, gentlemen...
I'm still wondering why Vasily's C3D 2013 cannot open the original drawing: perhaps has it been created by a 2014 release?
Message 8 of 17
troma
I thought 2014 drawings could be opened by 2013. At least, that was the intention.
Mark Green
Working on Civil 3D in Canada
Message 9 of 17
AllenJessup
According to Autodesk a 2014 drawings should open in 2013 and have the Civil 3D objects usable. In any case it should have opened in 2013 with proxy objects if nothing else. Maybe it was exported from another piece of software and was supposed to be compatible but wasn't quite. You'd have to pick apart the drawing file to find out. The only thing I know how to tell from a drawing file is what version it was produced in.
Just good that TrueView was able to rescue it. I wonder if any Civil 3D objects survived. I wouldn't think so.
Allen Jessup
Allen Jessup
Message 10 of 17
antoniovinci
in reply to: troma
@ Vasily
Could you paste here the first 6 characters of the original .DWG opened in Notepad..?
Message 11 of 17
Vasily_BC
AC1021
Message 12 of 17
Vasily_BC
I doubt that it was 2014 version.
Message 13 of 17
AllenJessup
That would be an AutoCAD 2007 release drawing file. So if it's the original file, it would be from an old version of the program. It also might have been a Save Back. Some trouble might have been created if the drawing was only saved back to the earlier version instead of using Exporttoautocad.
That's all speculation anyway.
Allen Jessup
Allen Jessup
Message 14 of 17
antoniovinci
AC1021 might be release 2007 up to 2009, according to this paper.
Sounds like that 2012 (i.e. AC1024) can't read 2013 files, while 2013 will be able to open even 2015 ones (AC1027).
Message 15 of 17
We are having problems opening some of our drawings as well.
Recently, our IT department upgraded our existing XP computers (32 bit) to new W7 machines (64 bit). We reinstalled AutoCAD C3D 2012, with ARD and Stringer including all Service Packs
This upgrade seems to have gone well with a few exceptions.
One or two of our drawing cannot be opened on the new  64 bit W7 computers.
They are typical drawing with nothing out of the ordinary in them
Opening these particular drawings runs as usual till it gets to 93% complete
An AutoCAD Application box appears with....
AutoCAD Application has stopped working
Windows is checking for a solution to the problem...
Then
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
Then AutoCAD shuts down.
I can then load the same drawing onto the XP machine without problem. I have purged out the drawing, resaved it but still it closes in W7 computer.
Any suggestions
Message 16 of 17
troma
in reply to: johnmcintoshtsc
Try running a 'recover' on the XP machine. If it fixes anything, try it then on Win7.
Another place you can get a clue is in the bottom left corner of the screen. Typically it will say
"Opening.....
Resolving xref....
Synchronizing references....
Keep an eye on that during the open, it might let you know what step is causing the crash.
Mark Green
Message 17 of 17
Thanks for the information.
I recovered the drawing on the old computer as requested but it still does not open.
There are no errors in the command lines as the drawing loads up.
As stated before, it gets to 93% and then closes
________________________________
John McIntosh | Chief Civil Engineering Designer
Engineering and Operations
[cid:image001.png@01CE45AC.C1C0E9E0]
p (02) 6670 2568 | f (02) 6670 2429 | e jmcintosh@tweed.nsw.gov.au | w www.tweed.nsw.gov.au
Civic and Cultural Centre Tumbulgum Road Murwillumbah NSW 2484 | PO Box 816 Murwillumbah NSW 2484
Customer Service: (02) 6670 2400 or 1300 292 872 ABN: 90 178 732 496
Our values: transparency | customer focus | fairness | reliability | progressiveness | value for money | collaboration
Please consider the environment before printing this email. One tonne of paper is equivalent to 13 trees and 30 kL of water
[cid:image002.png@01CE45AC.C1C0E9E0]
______________________________________________________________________
All official correspondence requiring a formal written response should be addressed to the General Manager, PO Box 816, Murwillumbah, 2484; or emailed to tsc@tweed.nsw.gov.au; or faxed to 02 6670 2429.
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to
whom they are addressed. If you have received this email in error please notify the system manager.
Opinions, conclusions and other information in this message that do not relate to official Council business shall be
understood as neither given nor endorsed by it.
This email has been scanned by the MessageLabs Email Security System
Rail Community
